Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 09 jul 2026 10:01
motorlampje 997
Bericht motorlampje 997
Bij het starten, na een bezoekje ergens, dus ook al even mee gereden, begon het motorlampje te flikkeren. Na van de parkeerplaats afgereden te zijn hield het op. Totdat ik een uur gereden had, toen brande het lampje continue. Ook de motor begon slecht te lopen leek wel op 5 cilinders. Toch thuis gekomen maar leek wel of de benzine er twee keer zo hard uit ging. Suggesties? ?????
09 nov 2014 10:01
911 3.2 Carrera
Bericht Re: motorlampje 997
Lambada sensor .....Luchtmassameter.....kortom, uit laten lezen bij de dealer.
09 nov 2014 10:04
Check Engine (Emission Control)
If the warning light in the instrument panel lights up permanently without flashing before and remains on while driving, it suggests:
Warning Light
– a potential engine control problem and the need for system service or
The emission control system detects malfunctions early that could, for example, cause increased pollutant emissions or consequential damage. Faults are indicated by a continuously lit or flashing instrument panel warning light.
– an improperly fastened tank cap or
– the vehicle was refueled while the engine was running
The faults are recorded in the control unit's fault memory.
>Stop immediately at a suitable and secure place and check tank cap for proper fastening. If tank cap was fastened correctly, see your au- thorized Porsche dealer for service as soon as possible.
The warning light in the instrument panel lights up when the ignition is switched on as a bulb check and goes out approx. 4 seconds after the engine starts. If the warning light does not light up, have the bulb replaced promptly.
Caution!
The warning light in the instrument panel flashes to indicate operating states (e.g. engine misfiring) which might cause damage to certain parts of the emission control system.
>In this case, immediately reduce the engine load by easing off the accelerator.
>In order to avoid consequential damage to the engine or emission control system (e.g. cata- lytic converter), have the fault diagnosed and rectified immediately at the nearest authorized Porsche dealer.
>Have the fault remedied at the nearest authorized Porsche dealer immediately.
Caution: :flush:
If the check engine warning light in the in- strument panel is flashing, serious catalytic converter damage and power loss will soon occur.
Prolonged driving with the check engine war- ning light on could cause damage to the emission control system. It also could affect fuel economy and driveability.
Hmmm, misschien had je toch beter het ding af kunnen zetten en Porsche assistance gebeld..... :| zo te lezen zijn de laatste twee regels op jouw probleem van toepassing.... maar misschien valt het mee.
09 nov 2014 10:42
Tnx voor de reacties. Heb vandaag m'n accukabel even losgemaakt om zo de auto te resetten. Het motorlampje is tot nu toe ook na een half uurtje rijden uit gebleven. Morgen heb ik een afspraak bij porsche leusden om en naar een hoge fluittoon in de motor te luisteten en meteen uit te laten lezen voor eventueel de co2 sensor of lambadasensor of hoe die ook heten mag. Ik had idd ook gekezen dat het die sensor kon zijn.
nog recenties over porsche leusden?
09 nov 2014 20:05
Dial_888 schreef:
Lambada sensor
:mrgreen: :mrgreen: :mrgreen: :ba:
10 nov 2014 7:53
ex RS4
Mijn auto is daar in onderhoud. En de vorigen ook. Kundige monteurs voor zover ik kan beoordelen. Kost wel duur daar. :cheesy:
10 nov 2014 21:15
Porsche diversen
Overijssel
Los van het lampje dat uit is.... loopt hij ook weer op alle 6?
10 nov 2014 23:08
