Pagina 1 van 1
Garage heating
Geplaatst: 25 nov 2008 23:12
door BTRIII
Can anyone give me advice on heating my garage.
The garage has power and gas, which of these 2 options are the cheapest and safest too run. i am looking for something i can bolt too the wall..a cheap and easy fix really as i am rebuilding next year.
Regards Martin
Geplaatst: 25 nov 2008 23:51
door Olaf
How big is the garage :?:
Is there also water available in the garage :?:
Geplaatst: 26 nov 2008 0:19
door BTRIII
No water
Aprox.5x3x2,5 not including the solder
Geplaatst: 26 nov 2008 0:25
door Olaf
You can make a central low pressure water heating system - by using a WEBASTO heater and maybe some (house)-radiators ...
... or find yourself a gasheater/blower ....
Geplaatst: 26 nov 2008 1:26
door BTRIII
the WEBASTO a good idea for the future, but for now i will settle for a low cost and safe gas/electric heater with thermostat. so any advice on this quick fix would be apreciated.
Geplaatst: 26 nov 2008 1:44
door PaulusdB
Any cheapo oil filled 'electrische radiatorkachel' would do, I guess.
I.e. no swirling dust from ventilator operated heaters. Or fire / CO hazards
from household gas or petrol ones.
E.g. Marktplaats € 22,50
like this one
Look for ones with 'vorstbeveiliging' (anti-freeze setting).
Geplaatst: 26 nov 2008 8:26
door Olaf
PaulusdB schreef:Any cheapo oil filled 'electrische radiatorkachel' would do, I guess.
Indeed "safer" - but to me it lookslike you need either a bigger one or at least two of these.
:@: BTRIII :arrow: Is your garage(door) insulated :?:
Geplaatst: 26 nov 2008 13:31
door BTRIII
Olaf schreef::@: BTRIII :arrow: Is your garage(door) insulated :?:
The garage is single brick from the 1930's the door is also not insulated (but i can fix that) thats why i am trying to keep the damp and cold out for the winter and planning to rebuild next year.
and when i say "cheap'' i also mean the running costs between gas and electric
@PaulusdB :arrow: Thanks, i will look into that but i think Olaf might be right with the output of that heater
Geplaatst: 26 nov 2008 13:34
door Olaf
BTRIII schreef:The garage is single brick from the 1930's the door is also not insulated (but i can fix that) thats why i am trying to keep the damp and cold out for the winter and planning to rebuild next year.
Maybe you should just get a humidifier :idea: :wink:
Geplaatst: 26 nov 2008 13:45
door BTRIII
if all else fails 8)
Geplaatst: 26 nov 2008 13:48
door BTRIII
i think you might be on to something there :!:
Geplaatst: 26 nov 2008 16:50
door WdePundert
I have one too. De humidity with it in this time of year is about 40%. When the temperature is lower it is harder to get it dry, than you need some heating.
