Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 04 nov 2026 6:55
Porsche 1969 Longhood RestoMode/ Outlaw ~ VERKOCHT ~
Bericht Porsche 1969 Longhood RestoMode/ Outlaw ~ VERKOCHT ~
Beschrijving
Base is a original non sunroof car wirh a 3 year restoration 1250 hours of work (2015 -> 2018) done by Provost Porsche / Sport Classic.
The car was fully stripped, shell was sandblasted and put on a rotisserie to make it as new as possible. All rust was repaired at the highest standard, all seams were extra welded to make everything stiffer.
All wear items like bushes, bearings, seals, fuel pump, starter, brake discs etc were replaced with oem or high quality ones.
The car has done more or less 6000 flawless kilometers since the restoration.
Last month the car did go the technical inspection with zero remarks.
Vraagprijs: 69.995€
MOD: New Asking Price as of Nov 17th: € 69.995,- See message from seller in a reply below.
Over 130.000€ was invested without the donor car.
+ 200 pictures of the restoration and all invoices are present.
Detailed info:
Outside
• Painted in gorgeous Viper Green with Glasurit
• Sandblasted, 110% rust free and reinforced
• Non sunroof car
• H4 headlights
• Steel original front S bumper
• Original S trim
• 7j ET23 Fuchs black matt heart with Yokohama A052 195/50 205/50 R16
• Extra set Fuchs deep 7R ET47 with Continental 195/65 205/60 R15
Engine, suspension etc..
• 3.2 engine
• 915 transmission
• Starter 1.5hp (P17940)
• Oil tank (P14846)
• Oil cooler front right (P30930)
• SSI exhaust & heat exchangers package
• FVD mass air flow meter performance kit
• 3.2 torsion front and rear
• Bilstein suspension
• Turbo Tie rods
• Supporting mounts (P15374)
• Master cylinder 23mm
• Kit to remove aluminium front calipers and fit discs 24mm (P111820)
Interior
• Oem carpet kit
• Momo Prototipo steering wheel
• RS door cards with houndstooth pulls
• Period correct LeMans seats with houndstooth fabric
04 okt 2020 11:25
Bericht Re: Porsche 1969 Longhood RestoMode/ Outlaw
En wat foto's...
$_84.JPG-1.jpg [ 16.58 KiB | 8860 keer bekeken ]
$_84.JPG-2.jpg [ 18.06 KiB | 8860 keer bekeken ]
$_84.JPG.jpg [ 43.27 KiB | 8860 keer bekeken ]
04 okt 2020 11:28
Kozijnenboer
Wow, prachtige auto. Goed bouwjaar :mrgreen: 217 pk?
Heb de schuur helaas al vol staan
Si vis pacem, para bellum
04 okt 2020 14:38
Bedankt voor het compliment, is echt een unieke wagen.
260pk :D
04 okt 2020 14:42
Hoe is de 3.2 motor opgebouwd :?:
04 okt 2020 19:40
Aan de Maas
Fraaie auto !, :cheers:
04 okt 2020 20:38
De 3.2 is een gereviseerde standaard motor gekoppeld aan een 915 versnellingsbak.
De maf kit (met nieuwe software enz) + SSI's geeft een vermogen van ongeveer 260pk.
06 okt 2020 12:22
Grote prijsdaling voor een snelle verkoop te genereren.
69.995€!
MOD: ook aangepast in je openingspost- GLWS!
17 nov 2020 12:34
als ik het had wist ik het wel :pale: prachtig auto
ps zet er nog wat meer fotos bij met oa de binnenkant
17 nov 2020 13:17
964 C2 '90
Fraai!! Zou ook wel wat meer foto's willen zien binnen en buiten..
Mooi groen is niet lelijk
20 nov 2020 13:56
Bussum
GLWS, hopelijk nu snel verkocht. ik vind hem lekkerrrrrr!! :mrgreen:
20 nov 2020 14:06
PF #911
België
Mooie auto! :shock: Is hier eind vorig jaar al eens voorbijgekomen bij de koopjesrubriek denk ik, vond het toen ook al een waanzinnig mooi apparaat!
968 ClubSport
GT86
MX-5 NA
Ex: Elise S1 111S
25 nov 2020 17:23
Thanks!
Met de prijsverlaging is er gelukkig veel animo dus zal niet lang meer duren :thumleft:
26 nov 2020 12:26
Is hij inmiddels verkocht?
01 jan 2021 8:58
Hallo iedereen,
De wagen is verkocht, mag een slotje op.
Thanks.
04 jan 2021 17:13
