Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 15 apr 2026 1:14
Solid-State DME relais Porsche 911 3.2L Carrera
Porsche 944 turbo 1987
Almelo
Bericht Solid-State DME relais Porsche 911 3.2L Carrera
Mochten er nog 3.2L Carrera rijders op zoek zijn naar Solid-State DME relais van Focus9 Technology?
Ik heb er nog een aantal liggen. Allemaal nieuw en ongebruikt. Een aantal basis relais (€ 109,--), een paar met pump-prime (€ 124,--) en een aantal met diagnostics (€ 134,--).
PUMP-PRIME
The Pump-Prime feature automatically runs the fuel for up to 3 seconds when the ignition is switched to the "On" position. This builds optimum fuel pressure before cranking the engine, insuring your Porsche starts as fast and as smooth as it possibly can.
DME DIAGNOSTICS
This optional feature allows you to instantly know the state of the DME Relay. It features four LEDs that are directly connected to the critical inputs and outputs of the relay. All four LEDs must be illuminated for the engine to start and run. If one or more LED(s) are off , there is an issue with the corresponding circuit.
    - Ignition SW – (Yellow) Input signal to power up fuel injection system and enable fuel pump control.
    - Fuel Inj. Power – (Red) Output indicating the fuel injection system is powered up.
    - Ctl. Fuel Pump – (Blue) Input signal indicating the DME has commanded the fuel pump on.
    - Fuel Pump – (Green) Output indicating the fuel pump is powered up.
944Parts.net - Nieuwe en gebruikte, originele Porsche onderdelen
14 apr 2026 11:00
