| porsche 997 met v8 van RUF rgt8 https://www.porscheforum.nl/viewtopic.php?f=24&t=26727 |
Pagina 1 van 1 |
| Auteur: | drknauf [ 03 maart 2010 22:54 ] |
| Berichttitel: | porsche 997 met v8 van RUF rgt8 |
![]() ![]() ![]() ![]() ![]() March 2010 and the time is right for RUF to announce the next generation of RGT, the RGT-8. This spectacular prototype vehicle is powered by a completely new RUF designed V8 engine with a 180° crankshaft “Flatcrank”. Four valves arranged spherically together with multipoint fuel injection ensure optimal mixture conditions while the dry-sump system supplies the necessary lubrication. The lightweight engine has a very compact design, has a capacity of 4.5 litres arranged as a V8 and delivers 404kW (550bhp) @ 8500rpm and complements with a maximum torque of 500Nm @ 5400rpm. At all stages of the design process, compactness and weight saving were of priority, the result of which is a total engine weight of less than 200kg. A 6 speed gearbox with shortened gear shift movement transfers the power to the rear axle. To ensure the best adhesion characteristics, the RGT-8 is supplied with Michelin Pilot Sport Cup tires running on 19 inch RUF forged alloy wheels utilising a single central retaining nut. The powertrain is rounded off with sturdy ceramic brakes as standard for optimal braking. The current Porsche 911 forms the basis for the RGT-8 chassis which is then further optimised with bodywork components from RUF. As always, an integrated roll-cage is supplied delivering increased chassis stability and passive safety. In addition, we are pleased to offer a Frère package which enhances the standard vehicle with special front fenders, nose and dashboard components. The styling was inspired by the 550 Coupé with which Paul Frère, the Belgian race driver, won the best of class at the 24 Hours of Le Mans in 1953. The RUF RGT-8 production start is planned for 2011 |
| Auteur: | drknauf [ 05 maart 2010 22:28 ] |
| Berichttitel: | Re: porsche 997 met v8 van RUF rgt8 |
| Auteur: | horn [ 05 maart 2010 22:30 ] |
monsterrrrrrrrrrrrrrrrrrrrrrrrrrrr |
| Auteur: | caelin [ 05 maart 2010 23:15 ] |
404kW (550bhp) @ 8500rpm dat zal een geluidje geven om van te smullen!! (het gewicht van 200kg voor een motor met 550 pk is natuurlijk B I Z A R te noemen) |
| Auteur: | Airhead [ 06 maart 2010 10:13 ] |
Waar ligt het zwaartepunt? Boven of onder de hoofdsteunen? Vanaf een bepaalde grootte kan je een dik blok volgens mij beter voor- dan achterin leggen.
