| lijstje specs 911 3.2 https://www.porscheforum.nl/viewtopic.php?f=24&t=43369 |
Pagina 1 van 1 |
| Auteur: | Hermen 2 [ 15 dec 2014 22:57 ] |
| Berichttitel: | lijstje specs 911 3.2 |
Porsche 911 Carrera 3.2 231 PS (1983-1989) Technical Specifications and performance figures Specifications Porsche 911 Carrera 3.2 Longitudinal Rear Engine : 6 cylinders flat 3164 cm³ 12 valves injection Power : 231 PS (170 kW / 228 hp) at 5900 rpm (Max RPM 6300 rpm) Torque : 285 Nm (29.1 mkg / 210 lb-ft) at 4800 rpm (~ 195 PS) Ratios : 73 PS/L (54 kW/L) - 90 Nm/L Transmission : Rear Wheel Drive + limited slip differential Gearbox : manual 5 gear Tires : 205/55/16 Front - 225/50/16 Rear Brakes Front : Ventilated discs Brakes Rear : Ventilated discs Dimensions : 168.9x65x52 inches Wheelbase : 89.4 inches - Track : Front 53.9 inches / Rear 54.3 inches Weight claimed : 1160 kg / 2557 lb (kerb) Weight (EU) : 1296 kg / 2857 lb (heaviest verified in running order) Weight/Power ratio : 5.6 kg/PS & 131 kW/T Torque/Weight ratio : 220 Nm/T Fuel consumption : economy 9.8 L/100 (24mpg) - sport 18.3 L/100 (12.9mpg) Indicative base price : ~38 700 € Launching year : 1983, end of production : 1989 Other engine technical information : Torque motor reserve 4 % Specific power 0.4 kW/cm² Mean effective pressure 11.1 bars Mean piston speed 14.6 m/s Engine optimisation rating 59 % |
| Auteur: | Hermen 2 [ 15 dec 2014 22:58 ] |
| Berichttitel: | Re: lijstje specs 911 3.2 |
Max Real Speed : 248 kph 400m : 14‚2 s. Km : 26‚1 s. 0 to 40 kph : 1‚8 s. 0 to 60 kph : З‚0 s. 0 to 80 kph : 4‚5 s. 0 to 100 kph : 6‚1 s. 0 to 120 kph : 8‚6 s. 0 to 130 kph : 9‚9 s. 0 to 140 kph : 11‚7 s. 0 to 160 kph : 15‚6 s. 0 to 180 kph : 19‚6 s. 0 to 200 kph : 27‚1 s. 0 to 220 kph : З5‚6 s. 60 to 100 in 4 : 9‚0 s. 80 to 100 in 4 : З‚9 s. 80 to 100 in 5 : 4‚8 s. 80 to 120 min : З‚7 s. 80 to 120 in 3 : 5‚0 s. 80 to 120 in 4 : 7‚6 s. 80 to 120 in 5 : 10‚З s. 80 to 180 min : 1З‚4 s. 100 to 140 in 5 : 10‚9 s. 400m from 40 in 4 : 16‚5 s. 400m from 40 in 5 : 18‚З s. 400m from 50 in 4 : 15‚З s. Km from 40 in 4 : 29‚4 s. Km from 40 in 5 : ЗЗ‚8 s. Km from 50 in 4 : 26‚1 s. 50 to 0 : 10‚5 m. 60 to 0 : 15‚2 m. 90 to 0 : З5‚1 m. 100 to 0 : 4З‚2 m. 130 to 0 : 77‚2 m. |
| Auteur: | Hermen 2 [ 15 dec 2014 23:01 ] |
gevonden op zeperfs altijd weer leuk die lijstjes! wel wat minder toen ik de Volvo V40 D4 erlangs hield hahaha Topsnelheid 190 km/u Acceleratie 0-100 km/u test : 8,3 s (7,4 s) Acceleratie 50-80 km/u in 3/4 : 2,6/4,6 s Acceleratie 80-120 km/u in 4/5 : 5,2/10,1 s |
| Auteur: | wolf [ 15 dec 2014 23:38 ] |
het klopt niet eens. |
| Auteur: | Hermen 2 [ 16 dec 2014 13:46 ] | |||||||||
| Berichttitel: | Re: lijstje specs 911 3.2 | |||||||||
wat dan wel? |
| Auteur: | Marco [ 16 dec 2014 15:49 ] |
of wat dan niet? |
| Auteur: | Rob69 [ 16 dec 2014 18:25 ] | |||||||||
Fout, ze zijn zwaarder.
| Auteur: | Rob69 [ 16 dec 2014 18:28 ] | |||||||||
Ook nie goed, het is echt 11m
| Auteur: | Enguess [ 17 dec 2014 15:43 ] |
Volgens mij standaard geleverd op 15 inch. Er zal wel meer niet kloppen, en/of marktafhankelijk zijn. |
| Auteur: | DLotus [ 17 dec 2014 15:55 ] |
Dat een V40 D4 rap is kan ik beamen. Dat mijn 993 sneller voelt / is kan ik ook beamen. Blijft toch een vreemde wereld waarin je met 14% bijtelling in een auto kan rijden die ruim een liter meer brandstof nodig heeft per 100 km dan mijn vorige leaseauto die 20% bijtelling gaf... Maar hey, je zult mij niet horen klagen...! Meer budget voor de Porsche |
