Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 25 okt 2026 12:42
CDR-24 nog steeds in 'Protect' mode
regio Waterland
Bericht CDR-24 nog steeds in 'Protect' mode
Afgelopen week op afspraak bij PC A'dam geweest om het issue met de 2de hands aangeschafte en zelf ingebouwde CDR-24 (als vervanging zeer verouderde PCM2...) op te laten lossen.
Helaas: de CDR-24 blijft nog steeds in 'Protect' mode, ook na twee uur ge-probeer door PCA monteurs(!).
Natuurlijk ook op andere fora gezocht en dan kom ik zaken tegen als:
"The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS"
en
"If you are trying to fit this radio (CDR-24) to a different vehicle, then you may find yourself with the Error message of "PROTECT". This stereo is electronically paired, or "Married" to the engine management system of the vehicle it came out of using very sophisticated MOST-BUS system technology. When it is first powered up, it will communicate with the vehicle, and a message of "PORSCHE" will appear on the display whilst this process is in operation. If communication has been successful, it will then operate in the normal way. However, if removed and refitted into a different vehicle other than the original one, it will not recognize the encrypted MOST-BUS identification of the new car, and will instead display an error message of "PROTECT" after around 30 seconds (in mijn geval is dit 'permanent'). This Radio cannot therefore be transferred from one car to another, unless it has first been reset back into its original "Delivery Mode" with the internal MOST-BUS data memory reprogrammed for use with the new vehicle. Porsche Dealers may tell you that this stereo cannot be reprogrammed to go into another vehicle, but then that's what they said about other models, before we managed to reset the MOST-BUS PROTECT system!
We can reset the PROTECT Error message for this radio, allowing it to be used in a different vehicle, but you will need to send the unit to our workshop for this work to be carried out."
Dat laatste, dat heb ik dus getracht; maar als ze het bij PCA al niet gedaan krijgen? Pfff... weet iemand van jullie misschien, hoe ik dit kan oplossen?
Erik
Take the long way home....
10 jan 2021 15:11
Profiel Twitter
Bericht Re: CDR-24 nog steeds in 'Protect' mode
Je zegt dat je geprobeerd hebt de CDR-24 op te sturen ...
Of begrijp ik je verkeerd :?:
10 jan 2021 15:37
regio Waterland
Nee hoor Olaf, de radio is mij uit de UK (toen kon het nog) toegestuurd met 2 VIN-nummers en ik ben met de auto + ingebouwde radio bij PCA langsgeweest...
10 jan 2021 16:31
Profiel Twitter
Ok, maar ik lees dit:
Welke workshop is dat dan :?:
Teile.com biedt er eentje aan - je zou eens kunnen informeren of die op fabrieks-instellingen staat en waar dat gedaan is :idea:
10 jan 2021 18:13
regio Waterland
...simpelweg een quote die ik vond op een US Porsche Forum...
10 jan 2021 18:19
Profiel Twitter
997.2 turbo S 993 4S
Boekelo
Erik,
Gevonden op Duitse PFF forum PFF
en op pistonheads deze
en nog een link op planet-9
Het lijkt "simpel" als je eea doorleest. Wil je graag helpen (heb een originele Porsche PIWIS). Heb nog niet eerder een CDR24 code uitgelezen maar wie weet komen we er achter hoe eea gaat.
Groet
Hans
10 jan 2021 23:59
regio Waterland
964hans schreef:
Erik,
Groet
Hans
Hans, Dank je Wel. planet-9 had ik idd ook gevonden. En ook dank voor je aanbod. Boekelo, in die mooie streek! Ik zou zo naar je toe rijden om het issue proberen op te lossen; als ik tijd kan vrijmaken - misschien ergens volgende week?
Eerst ga ik (toch) nog een keertje terug naar PCA, want ik heb hier €200 afgetikt, voor nul resultaat (okee: en twee nieuwe ruitenwissers...) :roll:
Het is toch te zot voor woorden. Dat zij het niet kunnn fixen... ik neem alle PIWIS- en MOST- tips mee en dan moeten we toch iets verder komen. Anders meld ik me!
11 jan 2021 9:50
Profiel Twitter
PCA heb ik sowieso niet hoog staan, vroeger vond ik ze erg goed en oplossingsgericht, maar ik heb enkele mindere ervaringen bij ze gehad de afgelopen jaren. Mijn auto's komen daar niet meer. Je kunt beter Leusden of PCG proberen als het bij Hans niet lukt.
11 jan 2021 11:08
Gebruikers op dit forum: kingkai
