Pagina 1 van 1
PASM 997
Geplaatst: 24 dec 2009 21:29
door 2000 gtv
Het lijkt me een zeer interessante optie maar ik kan hier maar weinig over vinden.
Wat is het(2 standen voor het onderstel heb ik begrepen) en hoe werkt het precies?
Zit het standaard op de S versie's?
Heeft iemand ervaring hiermee?
Re: psam 997
Geplaatst: 24 dec 2009 21:35
door Rob986
Als je googled op "Porsche Active Suspension Management" kun je je een paar avonden vermaken, incl. de nodige youtube filmpjes. Kom je de kerst zeker mee door.
Have fun.
"Porsche Active Suspension Management (PASM) is an electronic control system which uses continuous damper adjustment to maintain optimum ride quality and comfort. The push-button system is standard on the 911 Carrera 4S and optional on the 911 Carrera 4.
PASM has two setup modes, “Normal” and “Sport”, with only minimal overlap between the two. While the former is a mix of performance and comfort, the “Sport” setup mode has a much firmer range of settings for greater performance capabilities. The system responds to changing road conditions and/or driving styles by applying a variable damping force within the defined range for the selected mode (“Normal” or “Sport”).
To do that, PASM uses a series of sensors that monitor all movements of the car's body. The PASM control unit then evaluates this data and modifies the damping force on each of the wheels. The results are a reduction in pitch and roll as well as consistent road-holding on all four wheels.
If “Sport” mode is selected, the suspension is set to a harder damper rate. If the quality of the road surface drops below a certain threshold, the system immediately changes to a softer rating within the “Sport” setup band and thus restores the car's grip and traction. When the road surface improves, PASM returns to the original, harder setting.
If “Normal” mode is selected, and the car is driven assertively, PASM automatically switches to a harder rating within the “Normal” setup band. As the dampers become stiffer, the car becomes more stable and responds more quickly to driver inputs.
In either case, the result is a car which can adapt the way it handles and rides to the driver's driving style."
Re: psam 997
Geplaatst: 24 dec 2009 21:37
door Rob Herfst
2000 gtv schreef:Het lijkt me een zeer interessante optie maar ik kan hier maar weinig over vinden.
Dat kan goed kloppen!
Maar ga nu eens zoeken op PSAM!
schrijf ik het ook nog weer verkeerd
PASM dus
Re: psam 997
Geplaatst: 24 dec 2009 21:40
door Rob986
Rob Herfst schreef:Maar ga nu eens zoeken op PSAM!
Er is zelfs een club van
http://www.psamnwt.com/
Re: psam 997
Geplaatst: 24 dec 2009 21:52
door Rob Herfst
Wat info over PASM en Sport Chrono (ook een optie die niet mag ontbreken, apie!)
viewtopic.php?f=9&t=25419&hilit=pasm
Re: psam 997
Geplaatst: 24 dec 2009 22:22
door wolf
ik weet niet of ik een self adapting onderstel zou willen.
goeie coureurs zijn dol op porsche omdat, bij een goeie setup, je precies weet wat ze gaat doen.
zo wilde van lennep al na een paar km z'n p terug die hij even uitgewisseld had met de frari van een collega.... hij kon er helemaal niets mee, levensgevaarlijk zei hij.
Re: psam 997
Geplaatst: 24 dec 2009 22:45
door Paul II
Re: psam 997
Geplaatst: 24 dec 2009 22:47
door Rob Herfst
kijk, kijk, kijk
, zelfs Wolfie is zich rustig aan het verdiepen in een serieuze upgrade
Re: psam 997
Geplaatst: 24 dec 2009 23:04
door wolf
Nou. Lees nog eens. Beetje zachter, beetje harder
Kan ook alleen maar stuk.
Nee, geef mij maar ouwe Billsteins. Weet je wanneer de billen langs komen
Re: psam 997
Geplaatst: 24 dec 2009 23:13
door Maarten
Het is gewoon veel te ingewikkeld voor je. Niet aan beginnen Wolfie.
Re: psam 997
Geplaatst: 24 dec 2009 23:15
door wolf
tss. knopje aan/uit toch
Re: psam 997
Geplaatst: 24 dec 2009 23:17
door Maarten
Yeah right. Dat vinden ze eng bij Porsche. Tis helemaal aan of een beetje aan
Re: psam 997
Geplaatst: 24 dec 2009 23:18
door Rob Herfst
http://www.youtube.com/watch?v=oM2_xdU6o4M&translated=1En ik begrijp wel dat van Lennep zijn 997 met PASM terug wilde ipv die F!
Re: psam 997
Geplaatst: 24 dec 2009 23:30
door wolf
z'n RSR
http://www.youtube.com/watch?v=y-cvL3DF ... re=relatedtja al die hulpmiddelen... wat zal ik er van zeggen
Re: psam 997
Geplaatst: 24 dec 2009 23:39
door Rob Herfst
z'n 997S
http://www.youtube.com/watch?v=B8ykYTcjWGQen nog een keer z'n 997S
http://www.youtube.com/watch?v=LfRw8RGcxTsEn ja, die hulpmiddelen.......wat is je professional opinion?
Re: psam 997
Geplaatst: 24 dec 2009 23:53
door wolf
[quote=].wat is je professional opinion?
[/quote]
als je het nodig hebt --> hoef je je helemaal niet voor te schamen
Re: psam 997
Geplaatst: 25 dec 2009 0:10
door 2000 gtv
he robbierob
Vandaar dat ik niet zoveel kon vinden.Pams leverde wel wat op maar dat zocht ik niet
o ja.. Jullie moeten de groeten van tommy lee hebben.
Maar goed PASM lijkt me voor zover ideaal.Maar hoe zit het met de hoogte van de auto.Is dat ook nog instelbaar?
Zo nee,is een 997 met PASM te verlagen en dat dit dan evengoed nog werkt?
Re: psam 997
Geplaatst: 25 dec 2009 0:22
door 2000 gtv
wolf schreef:ik weet niet of ik een self adapting onderstel zou willen.
Juist wel omdat de omstandigheden altijd weer verschillen en veranderen, net als de "mood" van de chauffeur.Dus als je maar 1 setup hebt is het natuurlijk altijd een compromis en nooit ideaal.
Maar goed, opinions are like...
Re: PASM 997
Geplaatst: 25 dec 2009 0:33
door Rob Herfst
Vroegûh was alles beter.....
Ga deze maar halen, knul en have fun with it!
http://suchen.mobile.de/fahrzeuge/showD ... abNumber=2
Re: PASM 997
Geplaatst: 25 dec 2009 0:46
door 2000 gtv
Mooi prijsje ook Beertje
Maar je weet dat ik een babyblauwe zoek he.Met ojanje GT3 wielen
Re: PASM 997
Geplaatst: 25 dec 2009 0:52
door Rob Herfst
Re: PASM 997
Geplaatst: 25 dec 2009 0:56
door Paul II
Gecorrigeerd
: de verlaging bij PASM is 10 mm, met sportonderstel 20 mm t.o.v. het standaard onderstel.
Als de aanslag van de veren is te verstellen dan zou extra verlaging mogelijk moeten zijn. PASM heeft dus alleen maar invloed op de demperwerking.
Re: psam 997
Geplaatst: 25 dec 2009 1:01
door Rob Herfst
2000 gtv schreef:Maar hoe zit het met de hoogte van de auto.Is dat ook nog instelbaar?
http://www.pff.de/wbb3/tipps-tricks/por ... ra-s-pasm/
