Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 08 okt 2026 22:02
lijstje specs 911 3.2
3.2 carrera
Capelle aan den IJssel
Bericht lijstje specs 911 3.2
Porsche 911 Carrera 3.2 231 PS (1983-1989) Technical Specifications and performance figures
Specifications Porsche 911 Carrera 3.2
Longitudinal Rear Engine : 6 cylinders flat 3164 cm³ 12 valves injection
Power : 231 PS (170 kW / 228 hp) at 5900 rpm (Max RPM 6300 rpm)
Torque : 285 Nm (29.1 mkg / 210 lb-ft) at 4800 rpm (~ 195 PS)
Ratios : 73 PS/L (54 kW/L) - 90 Nm/L
Transmission : Rear Wheel Drive + limited slip differential
Gearbox : manual 5 gear
Tires : 205/55/16 Front - 225/50/16 Rear
Brakes Front : Ventilated discs
Brakes Rear : Ventilated discs
Dimensions : 168.9x65x52 inches
Wheelbase : 89.4 inches - Track : Front 53.9 inches / Rear 54.3 inches
Weight claimed : 1160 kg / 2557 lb (kerb)
Weight (EU) : 1296 kg / 2857 lb (heaviest verified in running order)
Weight/Power ratio : 5.6 kg/PS & 131 kW/T
Torque/Weight ratio : 220 Nm/T
Fuel consumption : economy 9.8 L/100 (24mpg) - sport 18.3 L/100 (12.9mpg)
Indicative base price : ~38 700 €
Launching year : 1983, end of production : 1989
Other engine technical information :
Torque motor reserve 4 %
Specific power 0.4 kW/cm²
Mean effective pressure 11.1 bars
Mean piston speed 14.6 m/s
Engine optimisation rating 59 %
15 dec 2014 22:57
3.2 carrera
Bericht Re: lijstje specs 911 3.2
Max Real Speed : 248 kph
400m : 14‚2 s.
Km : 26‚1 s.
0 to 40 kph : 1‚8 s.
0 to 60 kph : З‚0 s.
0 to 80 kph : 4‚5 s.
0 to 100 kph : 6‚1 s.
0 to 120 kph : 8‚6 s.
0 to 130 kph : 9‚9 s.
0 to 140 kph : 11‚7 s.
0 to 160 kph : 15‚6 s.
0 to 180 kph : 19‚6 s.
0 to 200 kph : 27‚1 s.
0 to 220 kph : З5‚6 s.
60 to 100 in 4 : 9‚0 s.
80 to 100 in 4 : З‚9 s.
80 to 100 in 5 : 4‚8 s.
80 to 120 min : З‚7 s.
80 to 120 in 3 : 5‚0 s.
80 to 120 in 4 : 7‚6 s.
80 to 120 in 5 : 10‚З s.
80 to 180 min : 1З‚4 s.
100 to 140 in 5 : 10‚9 s.
400m from 40 in 4 : 16‚5 s.
400m from 40 in 5 : 18‚З s.
400m from 50 in 4 : 15‚З s.
Km from 40 in 4 : 29‚4 s.
Km from 40 in 5 : ЗЗ‚8 s.
Km from 50 in 4 : 26‚1 s.
50 to 0 : 10‚5 m.
60 to 0 : 15‚2 m.
90 to 0 : З5‚1 m.
100 to 0 : 4З‚2 m.
130 to 0 : 77‚2 m.
15 dec 2014 22:58
3.2 carrera
gevonden op zeperfs
altijd weer leuk die lijstjes!
wel wat minder toen ik de Volvo V40 D4 erlangs hield hahaha
Topsnelheid
190 km/u
Acceleratie 0-100 km/u test : 8,3 s (7,4 s)
Acceleratie 50-80 km/u in 3/4 : 2,6/4,6 s
Acceleratie 80-120 km/u in 4/5 : 5,2/10,1 s :shock:
15 dec 2014 23:01
het klopt niet eens.
15 dec 2014 23:38
3.2 carrera
wat dan wel?
16 dec 2014 13:46
of wat dan niet? :mrgreen:
16 dec 2014 15:49
3.2 - '88. Schieffergrau met grijsgroen interieur. Schuifdak, geen airco en geen kat
Fout, ze zijn zwaarder.
“ If you always do what you did; you will always get what you got – and even less” - Albert Einstein
Laatst bijgewerkt door Rob69 op 16 dec 2014 18:29, in totaal 1 keer bewerkt.
16 dec 2014 18:25
Hermen 2 schreef:
50 to 0 : 10‚5 m.
Ook nie goed, het is echt 11m
16 dec 2014 18:28
Volgens mij standaard geleverd op 15 inch.
Er zal wel meer niet kloppen, en/of marktafhankelijk zijn.
17 dec 2014 15:43
Scheveningen
Dat een V40 D4 rap is kan ik beamen. Dat mijn 993 sneller voelt / is kan ik ook beamen.
Blijft toch een vreemde wereld waarin je met 14% bijtelling in een auto kan rijden die ruim een liter meer brandstof nodig heeft per 100 km dan mijn vorige leaseauto die 20% bijtelling gaf... Maar hey, je zult mij niet horen klagen...!
Meer budget voor de Porsche ;-)
17 dec 2014 15:55
