Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 25 apr 2026 7:24
Antwoord op onderwerp  [ 1845 berichten ]  Ga naar pagina Vorige  1 ... 45, 46, 47, 48, 49, 50, 51 ... 74  Volgende
Formule 1, Seizoen 2016
Cayman S
Bericht Re: Formule 1, Seizoen 2016
Het kan, maar op de fia site en andere site's staat niets vermeld.
Mooie race, jammer dat Rosberg niet de pech van Hamilton van vorige week had. Was. ook natuurlijk niet te verwachten.
De Ferrari's gingen erg goed tot aan de 2e pitstops, vreemd
Mvg,
René
09 okt 2016 10:35
http://www.dumpert.nl/mediabase/6905607/1d5d13da/verstappen_vs_hamilton.html
:salut:
09 okt 2016 10:45
Cayman S
Info van Motorsport.com
Charlie Whiting and the FIA stewards at the Japanese Grand Prix about his defensive move against Lewis Hamilton in the closing stages of the race.
The Dutchman was defending second place from his Mercedes rival on the penultimate lap when he moved to close the door on the entry to the final chicane.
Hamilton was forced to switch to the left hand side of the track, and ran down the escape road, coming over the team radio to complain that Verstappen had moved under braking.
Although there was no formal investigation of Verstappen's actions, Motorsport.com has learned that both Whiting and the race stewards – including former F1 driver Emanuele Pirro – spoke to the Dutchman about what happened.
It is believed that they wanted to clarify the situation informally with the Dutchman, as moving under braking is something the FIA does not wish to become a common accepted practice.
The incident with Verstappen was viewed as similar to what he did against Kimi Raikkonen in Hungary – rather than his blocking moves on the straight at the Belgian Grand Prix.
No action will be taken against Verstappen for what he did in Japan, but it is likely he will have been told explicitly where the FIA draws the line between what is and is not acceptable.
Mvg,
René
09 okt 2016 10:48
Wàt een gel*l weer. Dit is zo langzamerhand echt een sport voor jankerds geworden. Max deed helemaal niks verkeerd en mr wereldkampioen (die toch al super ongelukkig overkomt de laatste tijd) deed maar éen echte poging en toen die niet lukte moest 'ie meteen huilen. Niet te filmen. Net als Vettel, die denk ik meer calorieen heeft verbrand met schelden dan met racen vandaag.
09 okt 2016 10:53
Veel dank voor het plaatsen van het "fragment" :cheers:
Het is inderdaad weer op het randje... Maar goed, geen straf, wel een "reprimande". Ik denk dat de stewards en Charlie Whiting een beter inzicht hebben in wat wel of niet kan bij het verdedigen van je positie dan de gemiddelde forummer. We zullen hun mening dus moeten respecteren.
09 okt 2016 11:25
Mercedes heeft nu idd een klacht ingediend.
09 okt 2016 11:58
996 C4S
http://www.motorsport.com/f1/news/mercedes-lodges-protest-against-verstappen-move-836579/
hamilton vond dat iedereen max met rust moest laten omdat hij gewoon goed reed .
Nu gebeurt er iets waarbij Hamilton zelf betrokken is en men raakt in paniek en klaagt!
Zwakjes hoor .
Max rijdt prima ,ik blijf er wel bij dat destijds de move tegen Kimi wel erg gevaarlijk was ,maar Hamilton backte Max ..... :scratch:
09 okt 2016 12:08
Noord-Brabant
Wat een jankerds zeg, en met Lauda voorop.
09 okt 2016 12:11
LEEUWARDEN
Met of zonder roze bril dikke flauwekul.
Dit is racen waar het omgaat. Hij deed niets fout. De ene dient slimmer dan de ander te zijn om te kunnen inhalen met dergelijk kleine snelheidsverschillen. Exact hetzelfde is van toepassing voor verdedigen. Dat is de sport. Het hoort niet zo te zijn dat degene met het beste materiaal automatisch wint. Ja Ham was ook deze keer sneller echter VES en zijn team slimmer en heeft dus gewonnen. Dit is racen zoals het hoort!
Hoop niet dat ze straks hem alsnog een straf zouden geven omdat ze het gevoel hebben dat ze een ieder een beetje tevreden moeten houden en na al het klagen nu toch eens overstag gaan.
Zou ongelooflijk zwak zijn!
09 okt 2016 12:25
Ik kan me niet voorstellen dat de Mercedes mannen gelijk krijgen. Sneu is het wel.
09 okt 2016 12:40
ex Carrera Coupe 3.2 1987
Ik denk dat het een optelsom is, ook van vorige races o.a. tegen Raikonnen.
Ik hoop het ook niet, maar denk wel dat Max deze 2e plek kwijtraakt.... :evil:
09 okt 2016 12:49
Wat een jankerds bij Mercedes. :cry:
09 okt 2016 12:53
Ik zal wel alleen staan met mijn mening maar ik vind dat geen racen.
Had je James Hunt indertijd zoiets gelapt had hij jou van de baan gereden om je een klop op je kanis te geven.
Vind dit eigenlijk dezelfde weg opgaan als de schwalbes bij voetbal. Kijk eens naar een match uit de jaren '60, een voetballer zou toen alles gedaan hebben om toch maar verder te kunnen lopen, ook al werd er naar zijn benen gemaaid, als er nu iemand op 1m van hen komt laten ze zich vallen.
09 okt 2016 12:55
Protest alweer ingetrokken door Mercedes op voorspraak van Hamilton.... :res:
09 okt 2016 13:07
996 C4S
:scratch:
Hhhhm gisteren liep Hamilton weg bij de pers conferentie ....
Lijkt wel of ze Hamilton weer wat krediet willen geven bij de fans ...any way just my 2 cents....
Move van Max vandaag was niets mis mee imho.....
09 okt 2016 13:14
Hamilton idd een huilebalk. Op die plek inhalen is al niet echt makkelijk, en als je wanhoopspoging in de laatste ronde dan mislukt en je moet beroepen op t zoveelste overbodige FIA regeltje, vind ik dat een kampioen onwaardig. Hoop dat Max gewoon 2e blijft.
EDIT: zie net dat Hamilton is uitgehuild, en Lauda ook. Mooi!
09 okt 2016 13:16
LEEUWARDEN
Zijn die MB jongen toch tot bezinnen gekomen. Was een aanfluiting geweest.
Beter ten halve gekeerd als...
Beter zo.
09 okt 2016 13:34
Bedankt voor het fragment.
Daar is te zien dat Louis inderdaad zelf zijn actie inzet terwijl hij al in de remzone zit.
Je kijkt tegen de achterkant van die vierkante bordjes aan bij het video fragment en hij zet hem in na het eerste bordje
Beetje krom om dan te zeuren over iets, wat je zelf ook doet (van lijn veranderen in de remzone).
09 okt 2016 14:50
Cayman S
@Frans D, Hamilton is een Engelsman en daarom schrijft je zijn naam waarschijnlijk als Lewis en niet als de Frans(e) versie Louis. :D
Mvg,
René
Laatst bijgewerkt door MY00 op 09 okt 2016 16:12, in totaal 1 keer bewerkt.
09 okt 2016 15:08
996 C2 MK1, DD Pajero 3.2 DiD SWB + Mini R59 ex Jag E-Type OTS 1963, ex Jag MK2 1961. Lieshout
Eind goed, al goed. Pluim voor Max.
Do I look like I give a damn?
09 okt 2016 15:38
Bedankt voor de correctie MY00.
Ik ken een Louis (ook een donker persoon), vandaar dat ik waarschijnlijk de naam fout schrijf.
Ben er geloof ik wel consequent in geweest. :lol:
Zal er op letten de volgende keer. :wink:
09 okt 2016 17:07
Cayman S
Met zo'n Nick blijft het natuurlijk ook moeilijk om niet terug te vallen op frans. :mrgreen:
Mvg,
René
09 okt 2016 18:40
Noord-Brabant
09 okt 2016 19:15
Lelystad
zoals eerder al gemeld toch een nuance ten aanzien van de 'jankerd' Lewis Hamilton kun je hier nalezen;
http://www.motorsport.com/f1/news/merce ... 36617/?s=1
Met andere woorden :res: voor Lewis. :popcorn:
09 okt 2016 21:42
Voor diegenen die de race gemist hebben is hier:http://www.dumpert.nl/mediabase/6905781/2f25e38e/samenvatting_gp_van_japan.html de samenvatting
09 okt 2016 23:09
