Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 11 jul 2026 9:16
hardtop boxster
EX: 2,2 E / 2,2 T / 964 C2 / boxster S 986/ Boxster S 987 NU: 993 Targa en 997 S Cabrio
Bericht hardtop boxster
kan je zonder aanpassingen een hardtop plaatsen op een boxster.
of moeten er dingen aangepast worden :roll: :?:
20 okt 2004 22:34
For those who don't know, the spin locks are the receptacles for the rear attachment points of the hard top. If you order a hard top as an option with your Boxster, the spin locks (obviously must) come with the car. If you don't, your car will not have the spin locks. But they come with a hard top that you order separately. If you don't have the spin locks, you'll see a little plastic plug the size of a quarter between the roll bar and the exterior body panel. This plug is removed to reveal the spin lock bracket, and is also put back in the spin lock when the top is off to keep dirt out. Installing the spin locks is impossible without having the right type of tool and knowing how to get to them (the tightener hex bolt head is in a very awkward location that is best reached when the car is being assembled at the factory). The front of the hard top attaches just like the soft top, with a tab on each side and a latch in the center. The rear has to two spikes that slip into the spin lock sockets. Each spike ends in a latch handle that torques the top down. Finally, the rear defroster cable is plugged in.
Meer hierover kan je hier lezen.
20 okt 2004 22:43
Rosmalen
Thnx Horn!
Zondag bij de slalom in Lelystad?
21 okt 2004 7:13
Niet rijden, wellich wel even kijken.
21 okt 2004 7:17
Idem :!: met t
21 okt 2004 9:31
