Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 15 jul 2026 4:30
Antwoord op onderwerp  [ 61 berichten ]  Ga naar pagina Vorige  1, 2, 3  Volgende
911GT2 RS
'01 996 C2 Cabriolet
Bericht Re: 911GT2 RS
Nieuwe foto's: KLIK
11 mei 2010 13:33
Dat zijn al oude foto's Lars van het prototype bij de aankondeging voor de dealers eerder dit jaar.
Heet van de pers heb ik dit persbericht:
May 12 - The time: seven minutes, 18 seconds on the Nurburgring-Nordschleife. The power: 620 hp. The weight: 3,020 lb (1,370 kilograms) in road trim with all fluids on board. The car: the new 2011 Porsche 911 GT2 RS.
90 More Horsepower, 154 lbs Less Filling
The latest 911 is the fastest and most powerful road-going sports car ever built in the history of Porsche. With horsepower (hp) up by 90 and weight down by 154 lbs (70 kilograms) in comparison with the previous 911 GT2, the new 911 GT2 RS has a power-to-weight ratio of just 4.9 lbs (2.21 kg) per horsepower, by far the best power/weight ratio in its class. These are the ideal ingredients for an ultra-high-performance sports car with supreme agility and truly blistering performance on the road. Perfectly illustrating Porsche Intelligent Performance, the 2011 GT2 RS achieves a reduction of approximately 5 percent for both fuel consumption and CO2 emissions when compared with the previous 911 GT2.
The 3.6 liter six-cylinder boxer engine features two variable turbine geometry turbochargers and provides power to the rear wheels exclusively through a six-speed manual gearbox. Equally impressive stopping power comes from Porsche Composite Ceramic Brakes (PCCB).
New tires were specifically developed for the 911 GT2 RS and measure 245/35 ZR 19 at the front and 325/30 ZR 19 at the rear, delivering cornering performance to match the straight-line speed. Extreme cornering dynamics are ensured by the setup of the springs, Porsche Adaptive Suspension Management (PASM), unique anti-roll bars, specific engine mounts and recalibrated Porsche Stability Management (PSM), whose stability and traction control functions can be switched off individually.
The combined effect of these developments is evident on the racetrack. In fact, the ultimate 911 accelerates from 0-60 in 3.4 seconds, boasts a top-track speed of 205 mph and laps the famed Nurburgring-Nordschleife racetrack in just 7 minutes and 18 seconds.
Unique Looks, Limited Production, Worldwide Appeal
In its looks, the new 911 GT2 RS stands out clearly from the other 911 models through the lavish use of carbon-fiber-reinforced components with a matt-black surface finish, even wider wheels (including flared wheel arches at the front), new light-alloy wheels with central locking and "GT2 RS" model designations on the doors and rear lid. Matte-finish carbon also graces the redesigned front spoiler lip and the 3/8th of an inch (10 mm) taller rear spoiler lip – which both enhances aerodynamics and provides extra downforce.
The interior of the 911 GT2 RS also exudes sporting performance in virtually every detail. Lightweight two-piece bucket seats made of carbon-fiber-reinforced plastic are standard, as are lightweight door panels with fabric straps instead of traditional door handles. The basic interior color is black, which contrasts with red elements, such as the seat center sections, the roof lining and segments of the steering wheel rim. The gearshift and handbrake lever are also finished in red alcantara.
Limited to just 500 units worldwide, the 911 GT2 RS will be available in October 2010. The GT2 RS is making its world debut at the Moscow Auto Show on August 25th, 2010.
12 mei 2010 9:41
Porsche 964 C4
hopen dat hij net zo hardcore rijdt als de gt3rs. Hij ligt wel goed laag op zijn wielen.
Wel beetje jammer dat een eigenaar 'normale' Turbo die +10k stuk heeft geslagen bij 9ff(of waarschijnlijk ook Ruf etc.) een 997 Tujbo heeft met 700+pk (en met de handrem ook een 2wd heeft).
Mja als je dat soort dingen niet aan je P wilt doen is dit wel het ultieme. Zou mooi zijn als er ook nog eens een geluid als een oude 930 met tubi's uitkwam.
12 mei 2010 10:12
996 Carrera '02 - M3 3.0 '94
Zevenbergen
Wat een bizar monster zeg!!!
12 mei 2010 10:20
Profiel WWW Facebook  Twitter
Dan heb je nog geen GT2 of GT2RS. De GT2 serie is niet gewoon een Turbo met achterwiel aandrijving ipv 4WD. Is een ander concept, ander onderstel, motor, body etc. etc.
12 mei 2010 12:12
1970 Porsche 911T Targa / 1999 Audi TT / 2008 Porsche Cayman S / ex 1959 Porsche 356 A Sunroof , ex 1960 Porsche 356 B, ex 1963 Porsche 356 C
Foto van het interieur van de GT2RS
Meer info op Liebe zu Ihm
www.loveforporsche.com
12 mei 2010 12:36
Je bedoelt het persbericht wat ik hierboven al geplaatst had :mrgreen:
12 mei 2010 22:21
Vanacht online gegaan, de webspecial :arrow: Webspecial GT2RS :idea:
13 mei 2010 10:04
zandhoven - belgie
Bericht porsche GT2-RS !
http://www.youtube.com/watch?v=K76qBP2zklU&feature=player_embedded#!
13 mei 2010 11:17
3.2S
010
De 911GT2 RS wallpaper is hier te downloaden.....
http://www.autowereld.com/wallpapers/de ... tikel=9975
13 mei 2010 15:24
Alle wallpapers van de GT2RS vind je in de webspecial. :idea:
13 mei 2010 22:43
Porsche 964 C4
@maurice: helemaal gelijk! :cheers: Dus 20k: andere veren+dempers+uitlaatsysteem+spoilert(je kan uiteraard nog meer doen), zou ik hem persoonlijk wel richting de 700pk willen.
Even serieus: GT2RS lijkt mij een meer dan geweldige auto! Bij het aantal pk's(meest aantrekkelijke kenmerk voor een groot aantal potentiële klanten) schoot mij meteen te binnen: voor een klein bedrag bovenop de prijs van een turbo laat je de gt2rs in het dagelijkse verkeer continu je achterlichten zien.
14 mei 2010 22:47
baal je dan als je dan nog zoek word gereden door een gewone 997 turbo mk2 met launch controle
oplettend oog had hem al zien staan op dinslaken :idea:
15 mei 2010 20:03
Zevenbergen
Wat mij opvalt is dat er toch gebruik is gemaakt van de 3.6 motor. Is dat dan de oude GT2 motor, of is dit een aangepakte 997 Mk II Carrera motor? Wel heeft ie de nieuwe turbo's, maar niet de motor van de Turbo. Why??
16 mei 2010 14:33
Wat ik begrepen heb is dat de GT2RS motor compleet nieuw opgezet is voor deze auto en niet zoals bij de eerdere GT2 modellen een wat aangepaste versie van de Turbo motor is die alleen de achterwielen aandrijft.
Het boekje is onderweg dus misschien kan ik het daar uit halen.
16 mei 2010 14:50
de 1ste gt2 en de laatste gt2 achter elkaar 8)
was ik net m,n camera aan het instellen komt er zo,n paasei achter staan :(
latahhhhhhh
16 mei 2010 22:00
Das geen standaard GT2 en al zeker geen GT2RS. Kijk alleen maar naar de spoiler. :idea:
Oh ik zie het al. Het is een aangepaste GT2 door APC.
16 mei 2010 22:34
17 mei 2010 21:30
911 2.4E Coupé (1972) 944 S2 Coupé (1991/2) 997 Carrera S Coupé (2007)
drknauf schreef:
Ehhh, heeft dat ding eigenlijk überhaupt nog bodemspeling?!? Lijkt wel een sjoelschijf... :shock: :pale: :roll:
Horses for courses....
17 mei 2010 21:51
staat in mijn optiek perfect zo op 20 inchers 8) als het het had gekund hadtie van mij nog lager gemogen :idea:
17 mei 2010 23:12
Aha, een soort duikboot? :wink:
18 mei 2010 0:08
en dan op z.n duits U boot jawohlski :mrgreen:
18 mei 2010 0:12
Dus eigenlijk geen 911, maar een U96? Immer wieder tiefer und breiter gelegt...
18 mei 2010 0:27
Zevenbergen
drknauf schreef:
Zo is ie gewoon het gaafste en natuurlijk het meest Bad Ass ;).
Black-black-black met goudgele details. Super!!
18 mei 2010 0:38
zeg ik net nog een keer jmmr datje door een nieuwe 997turbo mk2 met launchcontrole in een 997gt2mk2 nog zoek word gereden op een sprintje van 0 naar 100 :cry:
18 mei 2010 10:08
