Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 16 apr 2026 5:45
Dit onderwerp is gesloten, je kunt geen berichten wijzigen of nieuwe antwoorden plaatsen  [ 33 berichten ]  Ga naar pagina 1, 2  Volgende
F(ront) P(rotection) B(ar)
Bericht F(ront) P(rotection) B(ar)
Nieuw item besteld bij Gert Carnewal.
Aanrader bij iedereen die z,n 993 heeft verlaagd of van plan is dat te gaan doen.
Het hele verhaal:
Many people lower their P93, some prefer the RoW M030 suspension that drops the car 25 mm all around, others like the P93 Rennsport set up that lowers the car by 50mm. The only disadvantage is that sometimes the car is literally coming closer to the ground with a damaged bumper or chin spoiler as a result. Steep driveways and speed bumps can cause a lot of damage.
On the market you'll find bars and boomerangs that protect the bumpers from scrapes, but they all require extra holes in the bottom of the trunk to install them. The holes you have to drill can cause the metal to rust.
Because I didn't want to damage my car by drilling 3 or more big holes in the sheetmetal , I designed my own "Front Protection Bar" .
"FPB" Testimonials"
The "FPB" installed on my '96 4S.
The car has the RoW M030 suspension.
No drilling:
The "FPB" attaches to 3 points that are already available on the car, so you don't need to drill extra holes that can cause rust.
Easy Installation:
The "FPB" comes with all the necessary hardware and can be installed without a hoist in less then 15min.
There is no need for special tools to install the "FPB".
Quality:
The "FPB" is made out of stainless steel and will not rust.
The side parts are laser-cut and guarantee a perfect fit.
All bolts and screws needed to install the bar are in stainless steel.
The stainless steel welding was done by a specialized company.
The weight of the bar is 0.7 Kg
Price for the US : 165 Euro shipping included Dollar Conversion
Price for Europe : Stuur Gert een mailtje met mijn naam
The "FPB" comes with all the hardware and detailed installation instructions.
Interested in having this bar for your P93, or do you have questions? Contact us
Click the picture for a bigger view
Read what others said about the "FPB"
IMPORTANT NOTICE
Beware of Front Protection Bars reproduced by a person in Ontario Canada.
These bars usually polished, poorly welded, not made out of stainless steel but chrome plated steel and don't have the laser cut side brackets
The person frequently uses our company name to sell his replica's.
Laatst bijgewerkt door RS-R op 02 feb 2004 13:54, in totaal 1 keer bewerkt.
02 feb 2004 13:46
Bericht Re: F(ront) P(rotection) B(ar)
En nu nog zoiets voor een 964/965 :wink:
In the Dutch mountains ...
02 feb 2004 13:53
Hé Humphrebay ..... nieuw item :roll:
http://www.marktplaats.nl/markt/autodiv ... m?zoek=993
02 feb 2004 14:32
EriC4C schreef:
Olaf was nog niet helemaal wakker AfbeeldingAfbeelding
EriC4C is nog niet helemaal wakker :mrgreen:
02 feb 2004 15:34
:? ..... Net Even Watanders :!: :?: :!:
02 feb 2004 16:48
Uden
Net gekocht!
Ben benniewd ofdat het wat uithaalt. Huidige eigenaar heeft hem er onder uit gehaald omdat ie continue met de bar tegen de drempels aan zat !!!
03 feb 2004 10:47
Marcel schreef:
Net gekocht!
Graag gedaan :^:
03 feb 2004 10:52
Uden
Eric4c,
natuurlijk bedankt...
03 feb 2004 15:55
Die FPB's zijn inderdaad wel handig om slijtage van o.a. de bandenbak tegen te gaan ... maar als je telkens met je FPB tegen de grond/op drempels zit is dat ook niet erg prettig .... staat je bandenbak aan het eind van de dag gewoon een centimeter naar achteren :wink:
Die van die 993 schijnen hetzelfde te zijn als die voor een 964/5 ... was gisteren bij Renntech -voor de strooiwagenschade- en we hebben even ge-brainstormed over een alternatief ..... wél functioneel, maar iets minder drempelvrees; Dé FPS ..... Ik hou jullie op de hoogte van de (prijs)ontwikellingen ...
11 feb 2004 11:06
Uden
Ik heb uiteindelijk de FPB NIET gekocht. Hij staat ook weer op marktplaats. Wat bleek- de FPB komt van FVD, dus moet je drie enorme gaten boren om te monteren, daar heb ik geen trek in, dan lijkt het middel me erger dan de kwaal..Moet erbij zeggen dat de verkoper (hans 993 - prikbord) dit uiterst correct opnam en er geen probleem van maakte.
FPS - moet zoveel beteken als een Front Protection Sheet, net zoals voor de 996, moet eenvoudig te maken zijn, ziet er beter uit. Ik houd me aanbevolen - hoef ik het zelf niet to doen.
11 feb 2004 11:43
Precies, het exemplaar van Carnewal maakt gebruik van bestaande gaten, dus geen geboor.
En dat je continu met die bar aan de grond komt klopt ook niet.Gebeurt wel eens dat zo'n vluchtheuveltje iets te enthousiast genomen wordt,
nu houdt die bar dat tegen.
Prima oplossing.
11 feb 2004 13:45
Cayenne
Dus eronder die dingen jongens, want je weet maar nooit of Pascal weer is een up-tempo ritje uitzet.
11 feb 2004 14:06
RS-R schreef:
En dat je continu met die bar aan de grond komt klopt ook niet ......nu houdt die bar dat tegen.
11 feb 2004 14:18
:lol: :lol:
moet zijn wanneer de carroserie de grond zou raken, etc......
vingertjes sneller als de gedachte :cry:
11 feb 2004 14:23
RS-R schreef:
:lol: :lol:
Kunt zeggen wat je wilt, maar met die FPR wordt het raakpunt NOG(!) lager, dus .....
FPS lijkt me inderdaad een betere oplossing. Niet voor mij Afbeelding, zeker nadat ik Olaf afgelopen zondag weer de nodige meters extra heb zien moeten maken terwijl ik gewoon rechtdoor kon ..... Afbeelding
11 feb 2004 14:51
Cayenne
Zal je vrouw leuk vinden. :lol: :lol:
En je klantjes :wink: ook
11 feb 2004 15:48
Nee, bij beide het "koppie" erbij.
11 feb 2004 21:38
Eric,
http://www.carnewal-europe.com/cpx_p93070t.htm
11 feb 2004 21:39
Cayenne
Jaja "koppie" tis dat ik je dubbelzinnigheid nu wel ff doorheb.
12 feb 2004 10:06
Ja :?: ..... prima bescherming voor verlaagde :wink: 911's, zeker monteren ..... maar beter nog een FPS :D. Als je het raakpunt gaat beschermen door er iets onder te monteren :roll: .....
12 feb 2004 10:47
Raakpunt bij 993 is erg kwetsbaar, vandaar.
12 feb 2004 13:37
** NEWSFLASH **
Dé FPS voor 964 & 965 is in productie - en zal onder voorbehoud ongemonteerd te zien zijn op 16 mei -
Voor prijsinfo & bestellingen kunt u terecht bij de FPS licentie-houder :wink:
06 mei 2004 10:25
‘64 Kever
* newsflash *
Spionage foto's van de FPS:
16 mei 2004 20:50
911 C2 Cabrio
Bericht oh
Dat was dat ijzeren ding op de tafel :idea: . Dat wil ik ook.
16 mei 2004 20:55
paSCal schreef:
* newsflash *
:mrgreen: Heb jij dat andere manneke niet gezien zeker ....
16 mei 2004 21:00
