Toon onbeantwoorde berichten | Toon actieve onderwerpen Het is nu 10 jun 2026 23:13
Antwoord op onderwerp  [ 69 berichten ]  Ga naar pagina 1, 2, 3  Volgende
Project 951 jonge man de eerste Porsche
Bericht Project 951 jonge man de eerste Porsche
Hi Greetings from Finland. When you can a bit english, german & swedish you can almost understand some dutch as wel :shock:
OK, i try not write any dutch or use translators, so hope you can understand my poor english.
We have build very slowly (about two years) a 951 for my eldest son. Since here in Finland we have world third highest car taxation (only those poor Greeks and Danes have higher), so we started from a car which is more or less a wreck.
Here's my son wondering would this be a wise move or not
Current state
Regards,
Olli
28 maart 2012 8:37
Bericht Re: Project 951 jonge man de eerste Porsche
nice project. welcome. good luck :wink:
28 maart 2012 9:14
Disagree :mrgreen:
Tervetuloa :!:
... which I cannot link with any English, German or Dutch word :|
28 maart 2012 9:21
Cayman S 2009, 924 1977
Welcome! interesting project!
why did you choose to put this on a dutch forum? is there a porsche forum in Finland as well?
28 maart 2012 18:26
Disagree
Tervetuloa
Well, quite many Dutch words sounds like english, german, or swedish. I suppose i am just good to figure out the sentence meaning.
We have a very good Finnish Porsche forum. I just hang around on German, UK, Swedish, USA, Italian, Estonian, Danish etc. Porsche forums . It's just nice to see what people do in the different countries.
29 maart 2012 8:01
Krimpen aan den IJssel
Good luck with your project Olli! Hope your son can drive his 951 soon!
Keep us informed, cheers!
29 maart 2012 9:37
Gemert, N-Brabant
nice project :popcorn:
29 maart 2012 12:42
looks like a big / nice project; welcome and please keep us updated (lot's of pictures!)
:salut:
29 maart 2012 13:17
We have taken a lot of pictures. Here's what son did after wreck was brought to his garage
Time flies, the same spot in the '90's
Back spring 2010
29 maart 2012 14:20
First we disassembled most of the car
29 maart 2012 15:36
Son prepared the engine room for the new paint. Car has suffered a classical 944 engine fire syndrome
And removed the torquetube & transaxle
29 maart 2012 15:37
Then it was time for a new paint in the engine room
Paint we used
My friend in action
29 maart 2012 15:37
Owner of 951 looks everything goes as planned
After 4 coats of Audi-Blue it's time for some clearcoat
After 3 coats of clear lacquer
Painter's daily driver
29 maart 2012 15:38
Son's project was already doomed to be a parts car. That's why previous owner has sold a lot of parts from it. So, we have spent some time to locate parts we need for the project. Also some clean up has been done. Most of the undercarriage parts will be either yellow passived or powder coated back to their original condition.
Some rear axle parts (bolts, nuts, washer etc.) in citric acid bath
Parts after citric acid treatment
Parts will look like this after new yellow passive (ZNC) tratment
My son managed to trade his old rusty original 951 stabilistors to the new ones. I suppose guy who agreed to this deal is some kind of mental case ;)
29 maart 2012 15:39
Got some pictures from Niklas who was the last owner of son's 951 in Sweden.Car was originally sold in Switzerland, then imported Sweden. Previous owner brought it Finlan.
Pictures were taken in 2005. We have a long way to go
If you don't have nothing to do in your summer cottage the Finnish lake distric (little bit over 200000 lakes over there) just clean and fix some of your 951's wireing loom
29 maart 2012 15:39
Booster turned out nice. Too bad i didn't take a pictures when it was rusty
Before picture
Most of the parts have been powder coated. Most undergarriage parts got rather dull "Platinum Grey" powder on them. We wanted to use powder coat, because it would be easier to keep these parts clean compared to "plain" aluminium. Here's picture of one control arm from where you get the idea of the color we used.
As a side project we re-contioned front brakes of friends 951
Restored clutch cylinders.Removed surface rust, then re- painted them. Since we are on tight budjet we used Mercedes W124 rubber parts, which are a direct fit also to 951. Total cost less than 10€
29 maart 2012 15:40
These will be the rear calipers of sons project (since owner is a poor student, we are on tight budjet)
Calipers were so sooty; that i put them for overnight citric acid bath
Calipers were sooty,rusty etc. because they came from this burnt 964 C4 and after 964 was wrecked they sat in backyard of my friends Porsche shop almost six months :(
I suppose most of soot will be able to wash off tomorrow morning. After that we will remove slide plates and pop off the pistons. Then some media blasting and calipers can be re-suface again to their glory again like they were when Luigi assembled them in Bergamo, Italy years ago
After overnight citric acid bath
Disassembled calipers.Some difficulties with burnt seals, which glued pistons very effectively. Also had to use mig to couple of screws to be able to take them off. Otherwise "business-as-usual" caliper job. Now they are ready to get a new surface.
29 maart 2012 15:41
Removing a stuck screw:
Disassembled calipers:
Warm weather continued on summer of 2010, so when it is just about 30 Celsius, it's good time to practice some excercise which needs strong muscles :) Since i am an old fart, it's younger men business.
My son put most of the rear axle to parts. Plan is to remove hubs & torsion bars tomorrow, after that these parts are ready to be media basted and some re-surface.
So it was my job to start heater/AC unit overhaul. Car's original unit was damaged in engineroom fire, but luckily previous owner was located a spare unit from a wrecked 1988 951 originally imported to Saudi-Arabia
Unit was really dirty, full of sand and some special plants leaves, most likely from Saudi-Arabia, at least i have not seen similar leaves here in Finland.
Starting point
29 maart 2012 15:42
After disassembly
img]http://i5.photobucket.com/albums/y170/olli951/3e637958.jpg[/img]
Parts looks quite good after washing
Putting back the flaps
At the same time we re-conditioned wiringharness. Old shield was in it's final stage
Jaybird hockey tape is #1 for this job !
finsihed wiring harness
Almost ready !
29 maart 2012 15:44
951's original heater/AC unit on left reconditioned Saudi replacement unit on right
Heater/AC unit install is near, so we checked out inside dashboard wiring. Otherwise it looked more or less OK, but wires which go to the engineroom to those big resistors were burnt more or less. Because copper wire conduct heat too good, we were forced to remove old tape a bit. After we removed a bit, we decided to remove all of it. Now it is easy to check out every single wire. We will build that damaged part and also remove badly done stereo installtion and replace it with ISO-connectors
Checking burnt part of wiring
Starting point looks quite good in the picture
But it was not so good after all. Some parts were so dry, that tape was more or less loose.
Now it is easy to make all repairs. After that we will put there few rolls of Jaybird hockey tape, as usual
Had some spare time, so we started with my youngest son Peter to fabricate some "tuning" parts for eldest son's 951. When you are on budjet, you do them by yourself. Well, just molds at the momet :)
Peter puts som gealcoat on (no masks were used, because it was very windy)
29 maart 2012 15:45
First glassfibre& epoxy added
Borrowed some hightech tools from my wife ;) Three sheets of glassfibre should be enough.
The finished product should look more or less like this
First mold is ready. Peter did great job with gealcoat
Here's the unfinshed mold:
We picked up about 50KG's of various parts from plater's shop. These has been plated with new liquids which does not contain chrome-6, which is now not allowed to use within EU countries. The shade of color is not as yellow as it used to be with "good-old-toxic" liquids.
We are going to change interior color from burgundy to black & marine Blue, so next step was to change roof liner color
29 maart 2012 15:45
from this
To this
We removed rear side windows to be sure black paint goes where it is needed.
Son bought a engine from Scotland
My son check out the condition of cylinder wall's. All 4 cylinders looked like new
My son bought a dump valve for his project. Similar ones will be installed by two friends of mine for their 951's. This valve is well known design here in Finland and have been on market over 10 years. Very popular on 500-1500hp drag race cars
29 maart 2012 15:46
Here's similar dump valve installed into friend's two 951's
3.0L street 951:
2.5L 951 track toy:
Here's a set of Techart (OZ) wheels son bought from a friend of mine
Fronts
Rears
Test fitting
Junior did some painting.Also this area was damaged by the engine fire. Area was easy to prepare after the damaged windshield was removed. Now there is a nice coat of satin black paint. Son also repaired wiring loom section which goes to heater blower and windshield wiper's motor. Now we are ready to install heater/AC unit and 968 dashboard :)
29 maart 2012 15:46
Got few parts from powdercoating
Reconditioned wiper mechanism
We did some heater/AC overhaul yesterday. The blower unit was quite dirty. First put it to the parts and removed mechanically most of the dirt
Well, we were not satisfied of the results, so i put parts to dishwasher :)
Now they look as they should
29 maart 2012 15:46
Got some parts from the platers shop. Now more or less all necessary pieces have yellowpassived or powder coated
Started also to restore the fusebox. Lots of "powder" from fire extinguisher there since car has suffered a classical 944 engine fire.
Test fitment
One side project; 968 Turbo front splitter. More or less ready to be molded
Some progress:
29 maart 2012 15:47
